Tractor Talk Discussion Forum
pulley removal, mover deck spindle
toakley
11-12-2005 14:27:47
Any suggestions, on how to remove the drive belt pulley thats seems to be rusted to the mover deck blade spindle? I have to replace the spindle shaft bearings.i've tried wheel pullers, heat & rust buster solvent. I'm at a stand still. The mover deck is off my AC B207. Any help? Thanks - Tom
Bob
11-12-2005 23:41:18
 Re: pulley removal, mover deck spindle in reply to toakley, 11-12-2005 14:27:47
Can you remove the whole spindle assembly, and support the bearing holder ("quill") in a press, and then push the spindle out of the pulley and the bearings at the same time?
I have done that on Deere mower spindles with the pulley stuck. I shears off the woodruff key as the spindle gets pressed through the bearings, but a new key is a lot cheaper than if I pulled on the pressed steel pulley, and wrecked it.
