Tractor Talk Discussion Forum
plans for a wood splitter
chris sweetland
11-07-2005 17:06:25
does any one have some plans on how to build a wood splitter i have three splitters there all diffrent but the same basic design i was wondering if there were any that were well balanced over the axle not too much on the toung or rear?
Hermit
11-08-2005 19:17:42
 Re: plans for a wood splitter in reply to chris sweetland , 11-07-2005 17:06:25
If you have a log splitter that converts to a vertical splitter, you can rotate the beam to about a 45 degree angle or so and hold it there with a rod. The splitter's weight will be then be balanced over the axles and easier to move.
doogdoog
11-08-2005 11:38:43
Aloha, Why do you want the trailer balanced?? Just curious.
Mahalo,
doogdoog
Wi Craig
11-08-2005 02:57:32
Can"t remember the formula, but you will run into big trouble if there"s not enough tongue weight. Craig
chris sweetland
11-08-2005 15:41:25
 Re: plans for a wood splitter in reply to Wi Craig, 11-08-2005 02:57:32
i am aware that i need toung weight i should have frased it centerd over axle this is because i move my splitters around by hand alot and they get real heavy
