Tractor Talk Discussion Forum
John Deere AR
AR
11-05-2005 19:28:05
Hi. I have a John Deere AR tractor and if I use it say for example drying grain the other day it will run good for about 2 hours and if I shut it off it will not start again until I change the sparkplugs. I have tried all different kinds of plugs in it and it doesnt seem to matter. I always have to go back to 2 old sparkplugs that are about 20 years old and it seems to run on them. If i put new ones in it will run good for a short time and then they are no good. If any one has some info for me i would appreciate it.
Glen in TX
11-06-2005 10:41:29
 Re: John Deere AR in reply to AR, 11-05-2005 19:28:05
After it shuts off like that check to see if you still got spark at the plug. It could be a bad coil? Bad wires? Wires heat and expand in coil and other wires also then not making connection and when things cool by the time you change the plugs it is making connection again until it heats up again and shorts and dies. Let us know more about the plug condition and what plugs you are using? Hard to say without knowing more. How long was it sitting before this? Could be fuel or fuel flow problems also?
thejdman01
11-06-2005 05:29:25
not to be an arse but what do you mean by no good????? ? wet????? ?//// brown????? ??/ black????? ?? champion makes a chart i dont know a link or anything that give pictures of the spark plug and what is wrong try to find one of those. w/o knowing what (bad) means we are just guessing. that is like asking my 2000 chevy truck doesnt run right what is wrong with it????? ????? ? w/o being there w/o looking at it jsut guessing but more info should narrow our guesses
bo
11-05-2005 19:44:40
That's not possible. At least I've never heard of that. Do a compression check and see if your cylinders/pistons are up to snuff. If you have good compression, check it after running. Also check to see if you have spark at the plug after running.
Nope, not possible. Can't wait for other responses.
