Tractor Talk Discussion Forum
rebuild hyd pump
jms
11-05-2005 01:04:25
how do you pull the seats out of the pump without
the nuday tool or were can you get one
Richard H.
11-06-2005 05:56:05
 Re: rebuild hyd pump in reply to jms, 11-05-2005 01:04:25
If I remember right you can use a 3-1/2 in. deck screw by grinding a flat spot on the head, or use a nail the same way. Just enough for it to fit down in the hole and tap the seat out. Pay attention to how it comes out as far as which way the bevel end goes. Richard
RodinNS
11-05-2005 14:45:51
I'm guessing that you're talking about a piston pump on a thousand series Ford? I've not had the pleasure myself, but in past conversations, I've been advised to get the tool should the need ever arise. You might also post this over on the Ford board, or check the archives there. I know it's been addressed in the past, and may have been sotxbill that had some suggestions on how to do that without the tool. That said, I know that the dealers in my area realise that there's no need being difficult about loaning out a tool like that from time to time. They might want a reference or a deposit, but I've always found them to be pretty good. HTH.
Rod
Roy Suomi
11-05-2005 04:25:36
Is it leaking around the seal?? Very possibly just installing a seal won't repair a shaft leak.Usually a bushing problem is the culprit causing the seal to leak. I don't want to pee on your parade , but I've been there . Seals on pumps just don't " go bad "...
