Tractor Talk Discussion Forum
Exhaust manifold tightening torque
TH
11-04-2005 14:49:36
What is the tightening torque of the exhaust manifold for a 1955 Fordson Major Diesel? I"ve seached the Intenet and this site and I"ve found manifold torque specs for different engines (but not the Major). They range from 20 to 50 ft-lb. I don"t want to brake the manifold so a correct value for this engine would be highly appreciated.
Kevin (FL)
11-05-2005 05:18:30
 Re: Exhaust manifold tightening torque in reply to TH, 11-04-2005 14:49:36
TH,
Torque charts are readily available on the web. You'll need to know size and grade of bolt. My guess is that the bolts are 3/8" or 7/16" grade 5. Probably will need about 30 ft-#'s with anti-sieze compound on the threads, but confirm the bolt size and then refer to the chart.
Go to this link for a chart:
