Tractor Talk Discussion Forum
Ford 961 throttle bellcrank question
jjp
11-01-2005 08:02:11
My Ford 961 throttle bellcrank had a spring which has been broken since I bought the tractor. The tractor runs fine, but when I am using the tractor the throttle slowly creeps down (ie, the rpms decrease). I am not sure what this spring did, but am wondering if this is the cause of my problem.
I have tightened the spider spring washer, but this doesn't seem to help.
Does anyone know if this will stop if I replace this spring Thanks!
Scott PA
11-01-2005 17:14:21
 Re: Ford 961 throttle bellcrank question in reply to jjp, 11-01-2005 08:02:11
The other end of the spring hooks to the small tab on the underside of the battery tray near the side you slide the battery in from.
Richard H.
11-01-2005 11:51:25
It seems like either the friction pad is oil soaked and or missing or just wore out. You can make one out of cork gasket material.HTH Richard
