Tractor Talk Discussion Forum
Rebuilding distributors
Don Ward
10-30-2005 15:12:25
I read a few years back about a fellow or company that would rebuild an old tractor distributor to give the engine more power. The weights are currently designed more for economy then peak horsepower. Does anyone know whom does this sort of work now? I tried searching many sites but found nothing. Thought I read it here a couple years back. Thanks for any help.
Jerry/MT
10-30-2005 17:26:01
 Re: Rebuilding distributors in reply to Don Ward, 10-30-2005 15:12:25
Usually auto electric shops can recurve the advance mechanism to give more advance than the standard factory advance curve but it is usually a trial and error process. If you have a stock engine, you don't have much, if any, to gain by recurving with more advance. You can try and see if it runs better with 2-4 degrees advance of initial timing. If it doesn't run better there than you're not lkely to see any improvement with a recurve.
