Tractor Talk Discussion Forum
38 B spoke rims
kooter
10-29-2005 10:53:49
I RECENTLY AQUIRED A 1938 B. IT HAS FLAT SPOKE CUT-OFFS ON IT. WAS THIS ANOTHER CHOICE THAT YOU COULD HAVE ON THIS TRACTOR WHEN NEW OR WAS THIS SOMETHING LATER ADAPTED.
ANOTHER QUESTION, TO FIND ROUND SPOKE CUT-OFF HOW EXPENSIVE AN D WHAT IS THE AVAILIBILITY OF THEM
THANKS
Leroy
10-30-2005 06:13:43
 Re: 38 B spoke rims in reply to kooter, 10-29-2005 10:53:49
Your last question, round spoke cutoff,s. You will not find them because the round spoke was ONLY with the rim for rubber and never for steel, the only way a round spoke would be a cuttoff is if the orignal rim went bad and was replaced. The flat spoke were only steel to start; I have heard that later as replacements there were flat spoke factory rubber replacement wheels made; and were cuttoff to use the better rubber tires. And I personaly like the flat spoke a lot better than the round spoke that to me does not look right.
MSM
10-29-2005 12:08:08
If it has flat spoke cut offs,the tractor most likely came new with steel wheels with spade lugs.As tires became more readily available,the steel rim was "cut off" and a regular rim was welded on and tire mounted.
A set of original round spoke wheels,with no cuts,rust,breaks or welds will bring $1200-$2000 for a rear pair with no tires.
old
10-29-2005 11:15:36
Well the flat spoke wheels where what it probably had from the day it was new. I own a 1935 JD-B with the same wheels it had on it when new and there the flat spoke ones.
105Diesel
10-30-2005 13:49:28
 Re: 38 B spoke rims in reply to old, 10-29-2005 11:15:36
Flat-spoke wheels for rubber tires on a 1935 "B"? Not from the factory.
old
10-30-2005 15:01:32
 Re: 38 B spoke rims in reply to 105Diesel, 10-30-2005 13:49:28
Did I say with rubber tires I don't think so. LOL He also said something about cut offs so he doesn't have factory wheels any more.
