Tractor Talk Discussion Forum
JD G EXCESIVE END PLAY ON CRANKSHAFT
SCOTT BONTRAGER
10-27-2005 19:34:09
I HAVE A 1947 JD G . THE PROBLEM IS THAT THIER SEEMS TO A LOT OF ENDPLAY IN CRANKSHAFT . MOVE FLYWHEEL UP CLOSER ON TO SHAFT BUT STILL AS END PLAY IN SHAFT MORE THEN THE SPECS IN THE REPAIR BOOK . IF ANYONE CAN HELP ME WITH THIS PROBLEM . PLEASE HELP
Specter
10-28-2005 07:29:44
 Re: JD G EXCESIVE END PLAY ON CRANKSHAFT in reply to SCOTT BONTRAGER, 10-27-2005 19:34:09
I agree with Buick's idea. I had the same problem with my 70 Diesel, and sure enough, one of the thrust washers was half chewed up. I can't help you more than that, as I've never worked on a G.
Mike M
10-28-2005 04:45:13
Your slinger may be stuck not letting the flywheel go on back farther.
buickanddeere
10-28-2005 04:36:46
Somebody may have snapped the little tang off that turns the thrust washer. A common occurance by tinkerers. The thrust washer will then eventually shred it's self. When the G was last apart, the tinkerer maynot have forced the pulley/crank all the way towards the flywheel side.The thrust washer may have fallen down when the seal cover was bolted on. Then it was pinched,crushed and shredded when the engine was rotated. The engine may have even been thrown together on the cheap with some home made substitute internal spacers made of leather,metal shims, baler twine etc. About all you can do is tear it down. Odds are it needs some other internal work as well.
Jerry/MT
10-27-2005 21:00:26
Whatever takes the crankshaft thrust is worn. Either a thrust washer or a thrust face on one of the main bearings. Not familiar with your specific engine but that is usually the problem.
