Tractor Talk Discussion Forum
1950 Farmall Cub Carb problems help ??????
T.r.y.
10-26-2005 17:47:03
I bought from a fellow recently not running. I have found it runs on starting fluid. He had replaced the original carb with universal zenith. Its seems like its not getting any gas. took it apart and cleaned it. It was like new inside. ????? ???
bradk
10-26-2005 18:25:08
 Re: 1950 Farmall Cub Carb problems help ?????? in reply to T.r.y., 10-26-2005 17:47:03
You have to verify if you have sufficient fuel from tank Also is your gas cap vented.If the float is not adjusted right,will not let gas past needle & seat.Also,look for a plug at carb or intake that might be missing causing a vacuum leak.Those up-draft carburetors need all the vacuum they can to pull air/fuel mixture up.~brad
Bus Driver
10-26-2005 18:22:04
The sediment bowl/shutoff assembly under the fuel tank may be clogged.
t.r.y.
10-27-2005 02:17:12
 Re: 1950 Farmall Cub Carb problems help ?????? in reply to Bus Driver, 10-26-2005 18:22:04
THanks for the helpgood clean gas coming down to carb with a good stream. tank pretty clean. Since I have no way in telling what to set the float at. I geuss I use try'll and error. done that before. thanks everybody. Trent
