Tractor Talk Discussion Forum
numbers to help i.d my ford tractor
oliveb
10-22-2005 10:12:28
Thanks to all those who responded to my 10-19 posting "what model is my ford tractor?" Here are the numbers you guys said to look for.
1. under battery- 821-DS, 36908
2. on axle- C128
3. on engine block above oil pan- 310609
4. on transmission- right side, 310835, left 310363
5. exhaust manifold- 310659
6. ford front loader- series- 703, component, I9-97, serial,8850
7. four speed transmission over/under
8. Has wide utility front end tires
9. Backhoe unit is a Sherman Power Digger serial 1100-3293
10. dash has fuel, temp, amp, and oil pressure guages
11. RPM guages read "hours at 1515RPM", also indicates "pulley 1316 RPM", "PTO 536RPM"
Any info you guys can find with these numbers would be great!!!!! !!!!!
john in la
10-22-2005 10:28:28
 Re: numbers to help i.d my ford tractor in reply to oliveb, 10-22-2005 10:12:28
8-Four-wheel adjustable axle w/172 cu. in. engine
2-Four-speed transmission w/o PTO or hydraulic lift
1-Series designation, 1958 to 1962
D-Diesel engine
S- do not know what s is for but think it was used on tractors that had the Sherman aux trans installed at the factory.
36908-serial #; makes it a 1958 Some can tell you what month but not me.
2. on axle- C128
this axle was made on March 12,1958
Those other #'s are just casting #'s
oliveb
10-22-2005 10:36:08
 Re: numbers to help i.d my ford tractor in reply to john in la, 10-22-2005 10:28:28
John in la Can you tell me what model I have so I can order manuals?
Dwight - VA
10-22-2005 11:52:12
 Re: numbers to help i.d my ford tractor in reply to oliveb, 10-22-2005 10:36:08
The model would be 821
Normally the 821 would have a 5 speed box but because you probably have the Sherman aux you could only get that with the four speed box.
oliveb
10-22-2005 12:34:34
 Re: numbers to help i.d my ford tractor in reply to Dwight - VA, 10-22-2005 11:52:12
Thanks everyone for the help!!!!! !!!!! Iam sure I"ll have more questions in the future>
john in la
10-22-2005 14:10:33
 Re: numbers to help i.d my ford tractor in reply to oliveb, 10-22-2005 12:34:34
If you order manuals you need the ones for a 801.
These manuals cover all 801 tractors. 811;821;841;851;861;871;881.
The middle # just tells what trans you have.
