Tractor Talk Discussion Forum
Right size of Mower for tractor
Tramway Guy
10-18-2005 07:03:48
I have an Allis-Chalmers 5030, 26 PTO HP. What would be the best size for a Brush Hog (or Bush Hog) rotary mower for this tractor? I am deciding between a 4' or a 5'. Want to do more than just cut grass. This tractor does have a very slow low gear.
David in Mo
10-19-2005 10:25:05
 Re: Right size of Mower for tractor in reply to Tramway Guy, 10-18-2005 07:03:48
We pull a 5 foot BushHog brand rotary cutter behind our 8N (which has less power) no problem.
Robert in TN
10-19-2005 00:35:26
Tramway, I have a '82 model AC 5020 that I bought brand new. It can only handle a 4' rotary cutter and a 5' groom mower. I would not go larger than a 5' rotary cutter and you may have trouble in high grass with that. As for groom mowers, you could probably get a 6' as long as you have decent grass to cut, a 5' would be ideal though...
Tim Shultz
10-18-2005 20:03:50
don't know what kind of grass you are choping, but in northern IN, I mow with a 5 foot chopper,
case 611B(64 hoss). I have to run in second gear to mow the heavy stuff, 'bout wide open. weeds no problem but the grass is a bit harder on 'em.
Tim Shultz
Chuck Bolton
10-18-2005 19:25:05
i have a WD--similar hp tractor--i have no trouble with 5 ft "brush hog." and have used an 8 ft pull type-- but it was a real load.
Dick L
10-18-2005 17:39:45
I have had a 5 foot finish mower and a 5 foot brush hog that I have used with my Symplicity 9523 which is the same as the Allis 5020. Both work just fine with it. They cover the width of the tractor plus. I have a loader with a 4 foot bucket. It is just slightly wider than the front tires but the rear turf tires are a bit wider. I chopped four acres with the brush hog two feet higher than the tractor in second gear this summer. Only problem was the screen in front of the radiator plugged and caused it to over heat about three times. I bought it new in 1980 and have used it rough all these years. For over ten years I mowed over ten acres of grass. Still starts and runs like a champ.
BobMo
10-18-2005 07:39:30
Better stick with 4'. You don't have a lot of tractor there so if your into something other than grass & weeds your going to have trouble....
RustyFarmall
10-18-2005 13:21:38
 Re: Right size of Mower for tractor in reply to BobMo, 10-18-2005 07:39:30
I don't mean to be picking on anyone, but "BUSH HOG" is a registered brand name. BRUSH HOG really isn't correct either, even though that's what everyone calls them. The correct term is rotary mower, or rotary brush cutter.
Tramway Guy
10-18-2005 13:56:10
 Re: Right size of Mower for tractor in reply to RustyFarmall, 10-18-2005 13:21:38
You are correct. But I wanted to make it clear that I wasn't talking about a belly mower or something else.
RustyFarmall
10-18-2005 14:56:21
 Re: Right size of Mower for tractor in reply to Tramway Guy, 10-18-2005 13:56:10
I understand, if you called it by the proper name most folks wouldn't know what you were talking about. That's the way it is, and probably always will be. Sometimes I just need to spout off, it wasn't directed at you or anyone else in particular.
steveormary
10-18-2005 16:21:53
 Re: Right size of Mower for tractor in reply to RustyFarmall, 10-18-2005 14:56:21
Tramway guy;
You could go with a 5ft. rotary cutter and not take a full swath if you are into heavy stuff. Also have a better chance of covering your tire tracks.
steveormary
