Tractor Talk Discussion Forum
sealer to use on exhaust studs?
mlm
10-17-2005 18:59:10
After I had the head worked on, the exhaust manifold studs seep engine oil. when I take them back out, what kind of sealer should be used on the threads?
barnrat
10-19-2005 06:19:33
 Re: sealer to use on exhaust studs? in reply to mlm, 10-17-2005 18:59:10
This situation is typical in modern automotive engines. Non hardening sealent on the threads works best.
Allan in NE
10-18-2005 05:40:38
MLM,
I agree with Marlowe on this one; those studs should be deadheaded, so if you're getting fluid, something is deceiving you.
Either the heat is boiling away residue oil in the stud holes or else your diesel is running cold.
My 966D has a brand new engine and I've been using it to dig postholes. It's been slobberin' all over itself because it is just not workin' hard enough.
Allan
marlowe
10-17-2005 20:20:34
you did not say what type of tractor you have gas or diesel but there is no way oil can come out of the studs if it's a diesel it could be unburned diesel fuel because it's not getting up to working temp. give us a better idea what you have
mlm
10-18-2005 10:05:24
 Re: sealer to use on exhaust studs? in reply to marlowe, 10-17-2005 20:20:34
its a 1978 Belarus. The top holes for the studs are drilled thought into the valve rocker compartment. the oil is seeping from the threads and not exhaust port.
Farmered
10-19-2005 03:08:07
 Re: sealer to use on exhaust studs? in reply to mlm, 10-18-2005 10:05:24
My experience with metric threads is that they don't fit as tight as USS threads. Try a high temp Locktight on the threads and set the stud as tight as you can using double nuts or a stud remover/installer before putting the manifold on.
Ed
