Tractor Talk Discussion Forum
Massey Ferguson 271 wont move in 3 and 4 high
Mike Alvarez
10-17-2005 04:07:33
hopeing someone knows, the tractor was running fine in 4th high was driving it to a field 2.5 miles away. when I got there I began mowing the field in 3 high and noticed it started to slow down by the time I finished mowing. I had to be in 2 high to leave the field on three and 4 high it would not move what could be the problem.
MSM
10-17-2005 04:20:54
 Re: Massey Ferguson 271 wont move in 3 and 4 high in reply to Mike Alvarez, 10-17-2005 04:07:33
Sounds like the clutch is slipping.Do you have any free play in the clutch pedal? Might get lucky with a clutch adjustment.
Mike Alvarez
10-17-2005 04:36:26
 Re: Massey Ferguson 271 wont move in 3 and 4 high in reply to MSM, 10-17-2005 04:20:54
if it was the clutch slipping why would it not effect 1 and 2 high.1 and 2 runs fine 3 and for it doesnt even try to move.
marlowe
10-17-2005 05:44:26
 Re: Massey Ferguson 271 wont move in 3 and 4 high in reply to Mike Alvarez, 10-17-2005 04:36:26
takes less force to move tractor in 1 and 2 then 3an 4 your clutch is slipping
marlowe
10-17-2005 05:47:33
 Re: Massey Ferguson 271 wont move in 3 and 4 high in reply to marlowe, 10-17-2005 05:44:26
also think about it ! if you run out of power do you shift to a higher gear no you shift down a gear . your clutch is bad
RAB
10-17-2005 08:20:54
 Re: Massey Ferguson 271 wont move in 3 and 4 high in reply to marlowe, 10-17-2005 05:47:33
Steady on Marlowe! I would say try it down a fair grade in high high - as long as the brakes are good! If it will go downhill alright, but starts slipping going up the ways, he will agree, the clutch is bad. By then (and probably by now anyways), the clutch will be not only bad but dead!
I"m with you. His clutch is bad.
Regards, RAB
Mike Alvarez
10-17-2005 10:58:49
 Re: Massey Ferguson 271 wont move in 3 and 4 high in reply to RAB, 10-17-2005 08:20:54
Thanks Guys I was hoping for a different solution. I guess your right Ill have to change the clutch.How difficult is it to change the clutch on a Massey Ferguson 271 I have been looking for a shop manual but can"t find one for the model
