Tractor Talk Discussion Forum
Hydraulic chatter
mtgummibear
10-16-2005 05:58:10
OK, so my tractor is not old, but I still need some help/suggestions. I have a 2001 New Holland 3010-S with a Bushhog Loader. Tractor has 600 hours on it.
Out of the blue about 2 months ago started to get jerky movement in the hydraulics. Mostly on the loader, but also noticeable on the 3-point lift.
I changed the Hydraulic Oil Filter and double checked fluid level and no improvement. I added more fluid to the point where I'm a little bit over-full, but still no change. Visual inspection shows no kinked hoses or lines, at least that I can see.
Does anyone have any suggestions about the possible culprit? With relatively few hours, I can't believe it's a problem with the pump already, but then again...they don't build them like they used to..:-) or something like that.
Larry
DLM
10-16-2005 19:57:10
 Re: Hydraulic chatter in reply to mtgummibear, 10-16-2005 05:58:10
I would check the suction line to the pump if it has hoses with clamps somewhere in the suction line it might be sucking air that will cause a chatter also check your suction screen in the resvore if it has one if a suction screen is partlly pluged up the chatter will be worse with cold oil. Also hoses with clamps will suck air but will not leak oil. Don
Johnski
10-16-2005 06:45:02
If you have any quick couplers on your tractor I would check to make sure they are fully seated and have not got any gunk in them. I have had fittings partially release and it can give those type of troubles. HTH... JF
twopop
10-16-2005 06:28:05
to the best of my knowledge,the chatter is caused by a piston style hyd pump.this happens when one or more of the check balls do not seal on the seat.
