Tractor Talk Discussion Forum
gas to alcohal conversion
chris sweetland
10-12-2005 15:13:53
i have a garden tractor puller it threw a rod and i am rebuilding it i was wondering how hard or what i would have to do to convert it to run on alcohal? also can i use my angle grinder to shave the head? or what would the perferd tool be? oh yea its a 12 hp kohler k 301 on a model 128 cub cadet
John S-B
10-12-2005 16:34:15
 Re: gas to alcohal conversion in reply to chris sweetland, 10-12-2005 15:13:53
An angle grinder to shave a head?!?! Man that's like using a machete to do brain surgery! Take it to a machine shop, that's a PRECISION operation. Don't try that at home kids!
RN
10-12-2005 16:18:27
Alcohal? On air cooled engine without a external oil cooler or filter may have problem preheating Ethanol. Try 2 fuel tanks- 1 gas, 1 Ethanol. have a steel fuel line for Ethanol close to head for a bit of preheat before going to carb. may try a Ubend toward front where warmed air can blow across line. Main jet on carb - enlarge about 10% and adjust from there. If trying Methanol- you will have graeter solvent affect on gaskets. Side valve engines for high compression- popup piston slanted toward valves- check old Ford hotrod ideas or Harley KHK pattern piston design. Watch out for gasket leaks- replace rubber with metal or teflon gasket material. check carb float for resistance. RN.
