Tractor Talk Discussion Forum
JD education 101
RustyFarmall
10-12-2005 08:07:07
third party image
Can anyone educate me as to what these parts are and what tractors they fit?
Part numbers are R38546, F2320, R224R.
RustyFarmall
10-13-2005 06:27:40
 Re: JD education 101 in reply to RustyFarmall, 10-12-2005 08:07:07
Thanks guys.
WeirdDeere
10-13-2005 01:38:14
Top left is a (Power) Steering Valve
Top right is a fuel transfer pump
Ralph listed their uses.
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
matthies
10-12-2005 19:29:13
The bottom two are PTO control valves for the side console 3020-4320 tractors. Just by seeing then don't know what model for sure, but more than likely they are shot, seen alot of these get replaced when I worked for Deere. If one of the above tractors mentioned came in with weak/poor hydralics you seemed to replace the valve and ended all problems. Last time I checked they were $600. I seen one independent shop replace the main pump, trans. pump, and a few other components until somebody told them to check the pto valve. Poor diagnosis, chris
Farm W/Junk
10-12-2005 21:35:56
 Re: JD education 101 in reply to matthies, 10-12-2005 19:29:13
Have a late model 4020 diesel side console that the hydraulics are tempermental. on start up it takes a little bit to get steering then you can pull out of the barn and all the sudden the 3 pt will go up the couple inches it settled overnight. where is this valve located? How hard to replace? Thanks
Matt
matthies
10-13-2005 04:53:48
 Re: JD education 101 in reply to Farm W/Junk, 10-12-2005 21:35:56
Your problem is different. Your check valve in the transmission is leaking. There is a kit to fix this at John Deere. It involves removing the elbow from the high pressure line from the trans. to the front pump. By removing the elbow you drill and tap the elbow for a check valve from a utility tractor hyd. pump. Your local JD dealer/somebody from here will hopefully be able to email you the procedure and part numbers. chris
ralph oregon
10-12-2005 08:43:02
r-224-r---70D-720-730D-80-830-I-840-R F-2320-R---50,60,70,70D,80-830I,520,530,620,630,720,730,720D,730D,840, and cotton picker 99,299
