Tractor Talk Discussion Forum
Alternator Wiring
JackT
10-11-2005 09:41:24
I need some help hooking up an alternator. Its an old Motorola 84 amp with the regulator attached to the back. There are two terminals, one marked OUTPUT (that one's a no brainer) and the other is marked STA. The remains of a crimp connector are attached to that stud so it was hooked up to something at one time, but what?
Thanks,
Jack
Bob
10-11-2005 10:02:21
 Re: Alternator Wiring in reply to JackT, 10-11-2005 09:41:24
Likely, 2 wires come out of the attached regulator, and connect to the alternator, black to ground, red to output of (+) rectifier.
How many OTHER wires come out of the regulator, and what COLOR are they?
STA = Stator... the raw AC output before the rectifiers. This can be used for various things... to operate an electric choke, or to operate a tachometer that uses the alternator's frequency to calculate the engine speed.
What was the original application of the alternator?
JackT
10-11-2005 19:24:03
 Re: Alternator Wiring in reply to Bob, 10-11-2005 10:02:21
Bob, I got the alternator off a street sweeper that was being junked. There are a total of four terminals--OUTPUT, STA, GND, REG. There are two pigtails coming out of the regulator--one connected to REG, the other to GND.
If STA is the unrectified output I don't see why I couldn't just ignore it and hook it up like a single wire alternator. Correct?
Thanks
