Tractor Talk Discussion Forum
Rotted out JD R block
Mark Wengert
10-04-2005 15:46:25
I have a JD R with a hole on the bottom of the block under the cylinder. It is about 1/2" by 1/4" in size. Is there a way I can fix this short of a new block? I was going to try Quick Steel and see what happens. I thought about welding but it is a big hole to weld up isn't it? Any suggestions are welcomed. Thanks Mark
JMS/MN
10-04-2005 23:25:37
 Re: Rotted out JD R block in reply to Mark Wengert, 10-04-2005 15:46:25
Bought an R years ago with the same problem- they don't completely empty out when you drain the water for winter. Had mine welded. Previous owner put on a disney patch of rubber and steel plate.
Earl-IL
10-04-2005 20:01:39
Drill it tap it put in a pipe plug. Earl
Island A
10-04-2005 17:57:38
You said under the cylinder, but is it through the cylinder wall? If it is just into the water jacket you could patch it. I have seen some really neat patches using flat steel, a gasket, and bolts around the perimiter of the patch.
Dave
Mike M
10-04-2005 16:28:08
I would think blocks are getting hard to find and expensive. I would take it to a professional welder that has alot of cast experience.
