Tractor Talk Discussion Forum
MASSEY TO30 HIGH/LOW RANGE? NEVER SEEN
FRED HOLTMANN
10-02-2005 16:12:30
I JUST BOUGHT A 1954 MASSEY TO 30 SERIAL # 113166
AND THERE IS A HIGH/LOW RANGE LEVER ON THE LEFT SIDE ABOVE FOOT REST. I NEVER SEEN THIS AND ALL MANUELS AND PEOPLE DONT MENTION ANY THING. PLEASE HELP IS THIS FACTORY OR EVEN COMMON?
marlowe
10-02-2005 17:54:21
 Re: MASSEY TO30 HIGH/LOW RANGE? NEVER SEEN in reply to FRED HOLTMANN, 10-02-2005 16:12:30
have [5] to-20s and three have the hi-low and i know of 5 or 6 more with it not rare. two of mine have it on the right one on the left. the ones on the right have three speeds up and down then out and up
Delbert from Lincoln
10-02-2005 16:31:58
The high-low on your tractor is an accessory. It was probably made by Sherman or Howard. There is a few of them around, not a lot, but rare enough to give your tractor bragging rights. If it is a straight thru, and lower gears, it would probably give you slow enough travel to use a roto tiller. If it is straight thru, and speed up or overdrive, I don"t know how much good it would be, except to give you a faster road gear. They were real popular on the 9N and 2n Fords with the 3 spreed transmission.
10-02-2005 16:22:57
The high-low range has been added as an acessorly. Probably either a Sherman, or a Howard.
