Tractor Talk Discussion Forum
IH 504 axle seal
fixer0070
09-30-2005 16:12:47
I am going to change an axle seal on a IH 504, can I do this from the outer end or do I have to take the axle housing off?
Weldon
09-30-2005 17:19:44
 Re: IH 504 axle seal in reply to fixer0070, 09-30-2005 16:12:47
No need to remove axle housing (rear axle carrier).
On Farmall model remove wheel from axle then remove the end cap from axle housing. On International (utility model) remove wheel disc then remove the rear wheel hub (attached with a 3/4 bolt in the center of the hub). Then remove the end cap from axle housing.
