Tractor Talk Discussion Forum
JD 440
BobMo
09-30-2005 05:29:12
My 440 has a 12v battery (positive ground) in it. The generator is there but not connected. It was running rough so I started checking it out and immediately saw that it need new points. I installed new points and condensor. When I took off the distributer cap the coil wire fell out of the coil. I checked the coil and found that where the coil wire inserts into the coil was completely eaten up so I bought a new 6v (internal resister) coil at the auto store and installed it. I haven't been able to get it to hit a lick since the change. What may I have done wrong?
NC Wayne
09-30-2005 21:55:59
 Re: JD 440 in reply to BobMo, 09-30-2005 05:29:12
Hey Bob, not really enough info to make a really good diagnosis but I'll go as far as saying if you've got a 12V battery you need to get a 12V coil instead of a 6V. Make sure when you hook the hot wire to the coil that you are hooking it to the poitive side, and that you do in fact have power on it when you turn the switch on. If it origionally had a coil with an external resister make sure you delete the old resister from the circuit when you put the new resister type coil in. Finally make sure that when you put the new points in that you set them to the proper gap. We've got a 440IC which has the same engine and it's pretty sensitive to having the right point gap. Check/try these things and if it doesn't work post again. Good luck.
BobMo
10-01-2005 14:08:35
 Re: JD 440 in reply to NC Wayne, 09-30-2005 21:55:59
Thanks, Wayne
