Tractor Talk Discussion Forum
Wisconsin V4
J Kelnhofer
09-29-2005 19:00:38
Need Help. Bought an old 610 bobcat with the v4 wisconsim motor and it wont run quite right. It Idles great and starts no problem. Will idle for about 20 minutes before it kills. When I ope it up it runs for about 40 seconds before it kills like I just shut the key off. I checked the filter,(actually I just bypassed it quick cause I did not have new filter), all the lines are clear, It has mechanical fuel pump and it pumps fuel awesome, line between pump and carb is clear. I'm assuming carb is fine cause it runs good for a while. So then I thought maybe the coil, so I borrowed the coil off my 630 case and it still does the same thing. Any Experts that can give me some other Ideas? Thanks in advance. - Josh K
Loren Coffin
10-03-2005 20:51:37
 Re: Wisconsin V4 in reply to J Kelnhofer, 09-29-2005 19:00:38
Had the same thing on my swather, took the cooling shroud tops off an started it up. Blew stuff EVERYWHERE. Mouse nests.
ERT
09-29-2005 20:00:09
Some Wisconsins have a hi-temp limit switch on the cylinder head shroud that can go bad and act like this.
paul
09-29-2005 20:11:39
 Re: Wisconsin V4 in reply to ERT, 09-29-2005 20:00:09
Yup, those with aluminumn heads I believe? Happened to my uncle's swather, threw the switch out & it ran great for years.
It could be a sticky needle valve in the carb, gas trickles through for idle, but not enough flow for full throttle once the float bowl empties, it shuts off.
--->Paul
Larry806
09-29-2005 19:26:06
I had a wisc that acted the same way. I put 2 sets of points & cond in it & I replaced the coil. Every time it would die it didn't have spark. If I used the points file just a little it would run a while again. A old friend that ran a shop over 50 years came down & brought NOS points & cond , same thing. We couldn't think of anything else to do so we gave up. A couple days later he called & said put that back in the shop. We took the plate out of the dist. that the points & cond fasten to, sanded the edges and the dist where it fits in. When we put it back together it never quit again. It was loosing ground for the points
2x4
09-30-2005 01:07:46
 Re: Wisconsin V4 in reply to Larry806, 09-29-2005 19:26:06
had same thing happen on IH pickup truck. Wire going out of the distributor wore thru insulation & shorted out against the plate. After it got cold, it started right up, ran 20 minutes & shut down.
Russ Smart
09-29-2005 19:06:26
Condenser!
J Kelnhofer
09-29-2005 19:24:26
 Re: Wisconsin V4 in reply to Russ Smart, 09-29-2005 19:06:26
Are you sure! Is that what happens? THat would be great if it was that simple.
Weirsdale George
09-29-2005 19:34:37
 Re: Wisconsin V4 in reply to J Kelnhofer, 09-29-2005 19:24:26
I agree that the condensor could be temperature sensitive.
I doubt if this particular item is you problem, but I'd check the gas cap vent to make sure it is open.
