Tractor Talk Discussion Forum
input shaft bearings in tranny on super h
mr. super h mod
09-27-2005 07:50:00
I need to put new bearings on the input shaft in the tranny on a 1953 super h farmall. What i need to know is what do i need to do to replace the bearings? Do i need to pull the top off to get to the shaft? Do i drop the lift all etc.
tn terry t
09-27-2005 18:23:16
 Re: input shaft bearings in tranny on super h in reply to mr. super h model 53, 09-27-2005 07:50:00
aint no reason to remove the top thats one heavy chunk of cast . drop the belly pump remove the drive shaft one hint i have found is to remove the belt pulley gearbox that helps you to be able to move the gears a little to match up the shafts PS watch for the little bearing in the end of the input shaft
riverbend
09-27-2005 17:48:38
You need to get a set of manuals for your tractor.
It is much easier if you remove the top cover, but I don't believe that it is necessary. You will need to remove the hydraulic pump.
