Tractor Talk Discussion Forum
need baler advice
cd in tx
09-25-2005 19:51:39
im looking at buing a new holland baler with a 2 cylinder wisconsin moter on it. it has been sheded and only has surface rust.rats made a nest in the twine but besides that looks good what is a reasonable price to offer for it.
DAVID Klaa
10-24-2005 13:36:40
 John deere T 14 baler in reply to cd in tx, 09-25-2005 19:51:39
I am looking at buying a T14 baler by John Deere,Not sure of the year of production. Any comments on what to look for on the T 14 (pro or con) baler.Apparently it works fine but some input from you guyw with experience with vintage balers would be much appreciated. Thanks David
Mike Van
09-26-2005 13:34:16
 Re: need baler advice in reply to cd in tx, 09-25-2005 19:51:39
cd. my IH 46 had a 2 cyl Wisconsen on it, worked well, in really good heavy hay I wished for a few more hp though. I don't know how heavy or hard you will use it, but like I said, you may find yourself waiting for it to catch up sometimes.
Dave H (MI)
09-26-2005 10:07:14
With or without the rats?
Tom in TN
09-26-2005 09:14:33
cd,
I second all the other guys have said. The proof of the baler is in the bales that it makes. It is probably obvious, but one way to test it without having to mow and rake a hay field, is to fork some loose hay into it while it is sitting stationary and see how the bales come out. I wouldn't consider buying it without seeing bales coming out of the back of it.
Good luck,
Tom in TN
TomTX
09-26-2005 05:29:44
Your post is a little short of info.
What Model is it?
When last run?
Will it start?
How long has current owner had it?
Galen
09-26-2005 05:00:31
Ask to take it for a test run. NH made these balers into the 80's, so it may not be terribly old.
tlak
09-26-2005 15:19:42
 Re: need baler advice in reply to Galen, 09-26-2005 05:00:31
They started in the 40s or 50s, so he needs to find out the model. ford or NH
Jonfarmer
09-25-2005 20:02:10
Looks aren't what really counts on a baler, it's how good it works. Don't offer more than you can afford to lose for an old baler. If you can start it and run a few bales though and see that it ties good, then it's worth alot more in my eyes. You didn't say what model, but by it having an old wisconsin motor on it, it must be quite old and alot of them have been wore out, but they can still look good, so beware!.
Hope this helps.
