Tractor Talk Discussion Forum
what is the difference between a 9n and a 2n ford
rowdyred
09-25-2005 09:59:25
what is the difference between a 9n and a 2n ford tractor
Leroy
09-26-2005 17:47:22
 Re: what is the difference between a 9n and a 2n f in reply to rowdyred, 09-25-2005 09:59:25
The 2N was the war time tractor and when it came out, no electricals, just mag ignation ans steel wheels with a hand crank and a chock rod thru the grill, was just a year or two that they were back to being equiped the same as the 9N's were. Most obvious differences were the 2N hood had the mounting bolts thru the doglegs and the 9N had hidden hood mounting, and the 9N had the I beam wishbone and 2N the oval and the 2N steering wheel was bare spoke while the 9N was all rubber covered
Bill Drew
09-25-2005 19:13:06
I believe the major difference is that WWII wage & price controls had been put in place. That meant Henry couldn't raise the price on the 9N so he produced a "New Tractor", the 2N. Since it was new, it could have a new (and higher) price.
Other differences are very few and very small.
had both
09-25-2005 16:08:25
very little
RandyN
09-25-2005 14:56:55
One other difference between the 9N and the 2N is when you own a 2N and people ask you what kind of tractor you have, you say "a Ford 2N" and then they get this blank look on their face an go, "Oh, what's that?" Many people don't realize that 2N's exist.
RandyN
Dave 2N
09-25-2005 15:57:24
 Re: what is the difference between a 9n and a 2n f in reply to RandyN, 09-25-2005 14:56:55
And some of them will tell you that no such model ever existed.
Redmud
09-25-2005 14:13:49
Bout 7 N's.
Mike (WA)
09-27-2005 08:11:30
 Re: what is the difference between a 9n and a 2n f in reply to Redmud, 09-25-2005 14:13:49
Made a bet with myself when I started reading the post the someone would say that. I won. Thanks.
Phil Munson NY
09-25-2005 14:48:32
You are one bad, sick, disgusting buckaroo. I really like that in a person. best Phil PS: "damn straight"
Redmud
09-25-2005 17:34:02
 Re: what is the difference between a 9n and a 2n f in reply to Phil Munson NY, 09-25-2005 14:48:32
Sorry Phil, the PS should have been, Right On" never could remember that dang Hippi stuff.
Redmud
09-25-2005 17:06:17
Thanks Phil, maybe, I reckon. PS: Left Arm"
Galen
09-25-2005 10:53:19
They were basically the same. 2N was introduced in 1942 and had several small differences to 9N. Most of them were due to war-time shortages in rubber, copper, and other materials (magnetos instead of batteries, steel rims instead of rubber tires, etc).
Bob
09-25-2005 10:25:13
They are basically identical in appearance and horsepower, having minor differences of more interest to purists and collectors, than actual differences in operation. Both have 3-speed transmissions.
The 9N was the earlier model, intoduced in 1939.
The 2N was the later model, introduced in 1942.
The 8N was introduced for 1948 (late 1947?), and is considered by some to be more desirable because of slightly more HP, a 4-speed transmission, and the added feature of depth control on the 3-point hitch.
Any of the three models could have an aftermarket auxillary transmission installed, giving overdrive, or underdrive, or over, direct, and under, depending upon the specific unit installed.
Link
Link
Mike M
09-26-2005 05:34:23
 Re: what is the difference between a 9n and a 2n f in reply to Bob, 09-25-2005 10:25:13
Didn't the 8N also put the brake pedals both together on the right side ? For those of us that don't have 2 left feet.
Tim B in MA
09-26-2005 09:41:52
 Re: what is the difference between a 9n and a 2n f in reply to Mike M, 09-26-2005 05:34:23
Yes the 8n has both brake pedals on the right; not one on either side like the 9N and 2N.
Rlach
09-25-2005 10:21:34
Not much, just details and improvements.
Same engine, trany, rear end. 8N is different, better engine, 4-speed trany, new hydraulic, ...
9N : began mfg in 1939
2N : began mfg in 1942, then up to 1947
8N : began mfg in 147, year model 1948.
Rlach
