Tractor Talk Discussion Forum
JD 316 Mule belt
Scott Lawrence
09-25-2005 06:04:27
I have tried to replace the belt on my J.D. 316 garden tractor but when I turned on the clutch the belt started smoking and the inside of the belt was all torn up. What did I do wrong when installing the belt? Smoke was coming from under the mule.
steve in in
09-26-2005 12:10:11
 Re: JD 316 Mule belt in reply to Scott Lawrence, 09-25-2005 06:04:27
You may have also had it cranked down to tight. Don't believe what that little sticker says. I believe you want about an inch or 2 of flex when you tighten it up.
MN Bob
09-25-2005 16:06:35
I agree with Kress, but, I have had a similar problem when a pully separated and the bearing was frozen. Not sure which happened first but gave me fits. wont hurt to check them see if they turn smooth and look good.
KRUSS
09-25-2005 07:02:08
I think you had the belt on the wrong side of some guides on the idler pulleys. I have done it and it cost me a belt , too.
