Tractor Talk Discussion Forum
JD 5020 fuel consumption
37 chief
09-24-2005 18:59:32
Does any one know how much fuel a 5020 uses per hour. When it is working, it is pulling a 14 ft. disc in dry ground. With the price of diesel the way it is, I may need to charge more. Thanks, Stan
Leland
09-25-2005 21:12:54
 Re: JD 5020 fuel consumption in reply to 37 chief, 09-24-2005 18:59:32
If you are only pulling a 14' disk you are wasting time equipment and fuel a 5020 should handle a 28-30 ft disk .
37 chief
09-25-2005 22:16:19
 Re: JD 5020 fuel consumption in reply to Leland, 09-25-2005 21:12:54
Since a 14 ft is all I have I have no choice but to use it. Can't afford to but another. Stan
Rlach
09-25-2005 10:16:02
From Nebraska tractor test 947 - 1966 :
In 4th gear, at 114 HP, this yield 13.85 HP-hour per gallon of Diesel or aroung 8.2 gallons per hour at full load.
Rlach
MSM
09-25-2005 07:16:29
I would figure about 8 gallons an hour minimum,possibly more depending on soil conditions and terrain.Maybe a little less if the tractor has a turbo.
