Tractor Talk Discussion Forum
engine cooling
larryinwa
09-17-2005 06:53:06
i have always wondered how they cool the engines on pulling tractors and dragsters-can't see any cooling system.
RayP(MI)
09-17-2005 18:22:10
 Re: engine cooling in reply to larryinwa, 09-17-2005 06:53:06
Some have been known to use tubular frame, and circulate the coolant thu the framework.
buickanddeere
09-17-2005 09:37:55
Thermal inertia of the block,heads and lube oil. If running on alcohol the heat absorbed by the fuel turning from liquid to vapour absorbs many btu's. The engines are operated rich which tends to lower over all temps. There maybe a gallon or two of coolant water in a tank gravity feeding the coolant jackets. The engine coolant stays at 212F as the steam boils off and is repalced with more coolant. Works too for the space shuttle the load bay doors are closed.
old
09-17-2005 08:51:03
Not sure on the pulling tractors but on the drag cars the engine isn't run long enouhg for them to really get to hot. Most drags only take a minute or 2 of running time on the engine and it take 10-15 minutes befroe and engine over heats
