Tractor Talk Discussion Forum
diesel motor oil flod
yann melcher
09-14-2005 13:34:59
My diesel tractor was parked on a hillside before one tire went flat and the machine flipped on its side.
Putting the tractor back on its tires I decided to start the engine.
It won't start! It always does. it barely turns. I can see the starter shaking and I can hear a bubbly like sound coming from the exhaust muffler.
I guess oil is in my combustion room (top of cylinder)?
Will the oil come down through ring to the oil pan if I let it sit a while ?
If so, how long?
What can I do ? please help.
Thank you
Yann
Jb
09-14-2005 13:49:20
 Re: diesel motor oil flod in reply to yann melcher, 09-14-2005 13:34:59
Yann,
Recommend that you remove glow plugs (if equipped) and turn the engine over until no oil discharges or you may cause serious damage. If the engine does not have glow plugs, remove the injectors and turn the engine over until no oil discharges.
If you try cranking before you get the oil out you may break rings, bend or break rods.
Good luck.
RAB
09-14-2005 14:07:42
 Re: diesel motor oil flod in reply to Jb, 09-14-2005 13:49:20
I second that approach. Hydraulic lock can easily bend a rod if one or more cylinders fire up.
Has the battery leaked electrolyte over tinwork?
Regards, RAB
yann melcher
09-14-2005 18:35:38
 Re: diesel motor oil flod in reply to RAB, 09-14-2005 14:07:42
Thank you all for your suggestions, I shall apply them.
No battery electrolyte has leaked.
I cranked a bit but engine did not seem to fire.
Hopefully crank and rods are ok
Thanks again
Have a good day.
