Tractor Talk Discussion Forum
Wanting to build cheap water tank.
Chances R
09-11-2005 20:15:48
Our local 4-H Center is in need of a water tank on wheels to water pulling tracks and to knock the dust down on gravel roads during events. Does any one have any good ideas for a 500 - 1000 gallon tank with motor and gas engine pump. Is a anhidrous tank a bad way to go? I think they scrap these from time to time?
Don-Wi
09-12-2005 21:10:47
 Re: Wanting to build cheap water tank. in reply to Chances R, 09-11-2005 20:15:48
How's about an old milk truck? My neighbor has a tank from an old milk truck mounted onto a really heavy running gear. Fills it w/ a garden hose(NO IDEA HOW LONG IT TAKES TO FILL) then hauls it to his other farm. He does this because the animals won't drink the water from the one farm, so hew hauls it fromt he other and stores it in 3 or 4 of those big plastic tanks.
Donovan from Wisconsin
Joe MD
09-12-2005 08:27:16
Seems like you could just use gravity. Why do you need a pump?
Chances R
09-12-2005 11:17:14
 Re: Wanting to build cheap water tank. in reply to Joe MD, 09-12-2005 08:27:16
Yes it may be worth a try. I am thinking like a 4" outlet to a horizontal 2" spray pipe.
Joe MD
09-12-2005 13:18:51
 Re: Wanting to build cheap water tank. in reply to Chances R, 09-12-2005 11:17:14
And don't forget a shut off valve in between.
Leland
09-11-2005 22:26:16
We just go to our local fertlizer dealer they will be more than happy to loan you a tank to pull around so everybody can see there name .
Chances R
09-12-2005 06:44:58
 Re: Wanting to build cheap water tank. in reply to Leland, 09-11-2005 22:26:16
Yes, we have been doing that but sometimes there are problems getting one for all the events that we do. I am thinking we need one for 6 or more events.
Leland
09-12-2005 19:11:20
 Re: Wanting to build cheap water tank. in reply to Chances R, 09-12-2005 06:44:58
We had the same problem but remember you have more than 1 dealer in the county I have had to drag one from as far as 25 miles away but they love the free advertising .
kyhayman
09-11-2005 21:03:22
What they use here is a plastic pickup mounted water tank (250 gallons) with a piece of 1" PVC with holes drilled in it as a spray boom that has 2 pc of angle iron and 2 u bolts to hold the pipe. Clamps on the back bumper with 2 pairs of vice grips and uses a 12 volt electric pump. I'd go electric, gas engines dont play nice if only started a few times per year.
Lefty
09-11-2005 20:58:32
Trailer or truck?..Old fire truck comes to mind initially...dunno the prices but farm stores usually have large plastic tanks for pickup or trailer mounting.
Ideal find would be a used smaller crop sprayer,was a LOT of them around awhile back with
"licensed applicator" requirements.Now most farmers(here)have quit do it yourself spraying and have it dome by contract.There are also some clever ATV rigs(Northern Tool)with 12V pumps that a garden tractor or such could handle.
Chances R
09-12-2005 06:47:23
 Re: Wanting to build cheap water tank. in reply to Lefty, 09-11-2005 20:58:32
I think a trailer may be the best way to do to less maintenance.
