Tractor Talk Discussion Forum
JD 720 L.P. Part 2
JD runner
09-07-2005 18:30:33
I'm thinking of purchasing a 1957 John Deere 720 L.P. with what looks to be a factory wide front. However the tractor's is sad shape. It has no good rubber, rims are about shot(one already is), the sheet metal is in very poor condition, and the engine is stuck tight. However the tranny seems like it might be ok. So how much is this tractor worth? All opinions are much appreciated.
First off I'd like to thank everybody for the helpful input. Second I'd like to clarify that this tractor has a 'row crop' wide front. Lastly a few of you suggested I run a serial no. check, how do you suggest I go about doing this. Thanks again. -JD
Jeff Oliver
09-11-2005 21:18:06
 Re: JD 720 L.P. Part 2 in reply to JD runner, 09-07-2005 18:30:33
We bought one a few years ago running and only needed paint for like $2700 I believe. Of course if diesel keeps going up hey might be worth alot more soon! been using ours in the hay field lately as we can buy propane for $1.29 /gal.
John (MO)
09-08-2005 05:33:37
To start with, go to the left side of this screen, look under "REsearch & Info", find "Serial Numbers" and click on it.
