Tractor Talk Discussion Forum
JD 4010 and white smoke
KYfarm
09-06-2005 07:54:58
I have a 1961 JD 4010 that very recently has begun belching white smoke out of the exhaust. Not at idle, only when given some throttle. It doesn"t sound any different than it did before but has begun using excessive amount of oil. Are there any signs to know if it is a bad valve versus piston ring problems without tearing down the whole engine.
HTR
09-06-2005 08:47:23
 Re: JD 4010 and white smoke in reply to KYfarm, 09-06-2005 07:54:58
Make sure your oil is not diluted whith diesel fuel. It can leak to the oil pan through the lift pump, or the seals on the injection pump shaft.
