Tractor Talk Discussion Forum
Kosch Steering wheel
Neilchm
09-05-2005 21:03:51
I have an international 340 with a Kosch steering wheel on it that I need to remove, but I am not having any luck. It has a large bolt down through the center, but I can't budge it. Any suggestions anyone???? Neil
doogdoog
09-05-2005 23:32:14
 Re: Kosch Steering wheel in reply to Neilchm, 09-05-2005 21:03:51
Aloha, If it has a large bolt and not a knot, I don't think that penetrating oil will help. I wouldn't use heat just yet, but I would try using an impact wrench gun. First, try using the reverse to loosen the bolt, and if that fails, try tightening it a little. Go back and forth and it should come out. If it does move, then squirt some penetrating oil going back and fourth. Take your time because you don't want to strip anything or break the bolt. TIA
Mahalo,
doogdoog
