Tractor Talk Discussion Forum
Just think what would happen.
old
09-02-2005 07:43:23
If say half of us that own tractors set up methane gas plants and ran one tractor 2 hours a day off that and used that tractor to run a generator to feed power back to the power companys. Doing so might really screw up how things are going right now.
NC Wayne
09-02-2005 17:36:21
 Re: Just think what would happen. in reply to old, 09-02-2005 07:43:23
Why not set up barges in the major rivers with massive water wheels on them driving generators. Water wheels provided power for many many years before electricity was even thought about, why withthe technology we have nowdays can't they moify them for this use. No damms for the environmentilists to complain about, etc etc. just clean naturally produce power.....
RustyFarmall
09-02-2005 10:36:04
I think the real answer is to use the wind and sun to generate electricity, and to run our cars, trucks and tractors on hydrogen.
buickanddeere
09-02-2005 14:04:12
 Re: Just think what would happen....nothing a lot in reply to RustyFarmall, 09-02-2005 10:36:04
Problem is you need to cover a fair percentage of accessible areas the US with solar cells to generate enough electricity. Plus solar cells don't work worth a darn on star or moonlight. The bunny huggers don't want plants and animals to try living in the shade. Having some land not blocked from sun and rain to farm on is a good idea too. As for wind, the environmentalists are complaining they look ugly, are noisy, birds run into them. And most of all they devalue their cottage or horse farm property values. Windmills don't work very well on calm, light breeze or heavy wind days either. The 1.6 Mega Watt Vesta units around here produce only 24% capacity in a year. And that's in the windiest part of the Province. Lets see, to replace the thermal and nuclear units here with wind at 24% capacity. We would only need 47,000 windmills. You will also be spending some time shivering in the dark. Don�t suggest storage in batteries..
RAB
09-02-2005 16:00:46
 Re: Just think what would happen....nothing a lot in reply to buickanddeere, 09-02-2005 14:04:12
B&D
That 24% figure is probably close to the design output.
All wind turbines will only manage about a quarter to a third of their maximum output over a year period.
There is unfortunately no other meaningful way of rating a wind turbine other than quoting max output.
For example, if some dummy put a mega-turbine where there was no wind at all, the output would be zilch. Offshore, where the windspeeds are generally more consistent (and higher) will lead to the higher end of the output over the yearly cycle.
About the same overall efficiency as the best photovoltaics, which are at most around 15% efficient at converting the solar energy which reaches them, as you say aren"t worth a jot in the hours of darkness, and also cost a great deal more per kilowatt installed.
Any reduction in fossil fuel use must be a good thing - and just think of the thermal efficiency of a coal fired generator at about 40% for a base load, and much lower for variable loads, ain"t that good either.
Whatever equation you use, the wind turbine will win over any "conventional" generator on energy input costs to electrical output, as the wind energy cost is effectively zero.
200 years ago in the UK there were windmills/watermills all over the countryside - and they were big buildings in those days, so lots and lots of smaller generators might be the answer to our problem of large "unsightly" turbines (although I think they are not too much of a problem as long as there are not too many in one area).
You have to realise there are a lot more people on this earth now, than even a couple hundred years ago, and that is one part of the problem also. Not suggesting 50% are done away with or whatever, but a great deal of those people are energy wasters.
I am an avid advocate of using less fossil fuels and I am very strongly in favour of using increasing amounts of sustainable or renewable energy along with using all energy more efficiently or more frugally as necessary. Time is running out on fossil fuel supplies - even if we have only used half of that available, we need to remember it has been "in the locker" for the last 200 million years or so and there is no more "in the production pipeline" for the foreseeable future. Furthermore, fossil fuel energy is really only solar energy which has been chemically stored for that length of time but all that locked up carbon has allowed the earth to function, as it has been doing, for the previous umpteen million years. Until now when humans are releasing all the stored energy, and possibly more importantly, all that carbon dioxide into our previously static atmosphere, all in a very short timespan. 200 years is after all only one millionth of the time fossil fuels have been locked away, yet some think it is their right to use whatever they like and to ignore the possible effects of what humans are doing to the planet, our only residential home at this time!
If 25 000 wind turbines would mean a 50% cut in therm electricity generation, that would be a great achievement.
Off soap box for tonite.
Regards, RAB
Shaggy
09-02-2005 09:35:17
In Peru IL. they run Diesel generators so many hours a night or maybe its a week and it keeps the power bill alittle cheaper. This is what I have been told anyway.
Jerry Cent. Mi.
09-02-2005 08:19:01
It's probably cheaper to setup a wind energy plant. We need to repair and replace some of the dams that were supose to be unnessary also. Lots of them have been dismatled.
Easy
09-02-2005 08:45:09
 Re: Just think what would happen. in reply to Jerry Cent. Mi., 09-02-2005 08:19:01
There were several small dams I know of in Michigan that have been dismantled in the last 30 years and none of them for enviormental reasons. Some were taken down or had thier generating equipment removed or made inoperative because the power companies, Detriot Edison an Consumer's power, only wanted large generating plants, they didn't want the smaller units. And some, including 2 near me, were breeched because the state deemed them unsafe, that is that they might give way and endanger the surrounding communities. I know of one spot where some older houses have boathouses and docks to a body of water that no longer exists. Electrical generation is apparently a large scale type of business. Easy.
jake3x
09-02-2005 08:43:55
Jerry have you ever seen the 2 wind generators at the Mackinaw bridge? These furnish electric power for the city and are huge, I've been told that they are rated 1,00000 watts each, but haven't researched that.
GeorgeH
09-02-2005 13:27:58
 Re: Just think what would happen. in reply to jake3x, 09-02-2005 08:43:55
Jake, thanks for post. I grew up 13 miles south of Mackinaw City and did not know about the generators. Course, it was 50 years ago since I was a permanent resident there.
WiCraig
09-02-2005 12:29:33
We have 2 large ones like these in Wisconsin around Oskosh. Talked to the power company on how much these babes cost. $1.6m each. So much for selling these thing to people like me. Even the small ones for running you house run over $10,000 I think.
grapefarmer
09-02-2005 11:13:00
Wind Turbines - May 28, 2002 - wind generators at the Mackinaw bridge.
Link
Dave H (MI)
09-02-2005 09:17:29
Since we are having a Michigan moment, I'll jump in and say that I haven't been across the Mac in a lot of years. Don't remember seeing any generators but then I probably wouldn't have noticed back then. Are these newer or did I miss them? I should probably get these kids up there to see the other half of the state sometime soon.
Seems like we always heading south. Probably the way y'all up there like it, eh? (sorry...couldn't resist, eh)
Easy
09-02-2005 09:34:33
 Re: Just think what would happen. in reply to Dave H (MI), 09-02-2005 09:17:29
One of my grandfathers was born and raised in the UP. I remember asking him why he moved down to Detroit. He told me that you couldn't eat scenery. About 10 years ago I remember reading that the UP was the only part of the country that had lost population in every census from 1900 thru 1990. It might be getting some back now, I don't know. Easy.
