Tractor Talk Discussion Forum
1969 international backhoe/loader 3444/2206 info r
missy presler
09-01-2005 08:29:32
Can anyone point me in the right direction? I have a 1969 international backhoe/loader 3444 that I need to pull the hydrolic pin for the backhoe.The teeth are stripped and the pin is leaking.The arm is not working properly.I was looking to find schematics and parts for it.Thanks for any help in advance.
missy presler
09-01-2005 11:12:13
 Re: 1969 international backhoe/loader 3444/2206 in in reply to missy presler, 09-01-2005 08:29:32
Still looking for help
Case450
09-01-2005 09:38:25
Could you be a little more specific as to which pins you need to remove? You mentioned something about the teeth as well, you wanted to change them or what? To change the teeth you punch out the old pins at the bottom of the shank and install new teeth. If your teeth are welded on you will have to grind them off and weld new teeth on.
missy presler
09-01-2005 09:46:24
 Re: 1969 international backhoe/loader 3444/2206 in in reply to Case450, 09-01-2005 09:38:25
It is the long pin that holds the backhoe onto the tractor.It's about 3 or 4 inches around I would guess.There is a bracket that is mounted to the tractor with teeth, that houses the pin then the pin has teeth that are supposed to mesh with it but all are worn so the pin is swiveling in the bracket.It like this-bracket,arm bracket,pin through all.
