Tractor Talk Discussion Forum
Rust neutralizers..
Stan(PA)
08-31-2005 13:45:51
I used a "rust neutralizer" on a rusted part. I sanded first, removing all the loose rust, basically leaving the "hard" rust, more of a "rust stain". The neutralizer turned the rust black, and everything seemed to be working as advertised. I decided to resand the part, and, as I sanded, more "rust dust" showed up. My question (finally) is this: does the neutralizer form a sealcoat that stops new rust? Or, does it simply change the very surface, and allow rust to reappear after paint? Sorry for the long post, but I figger somebody out there has used this stuff, and could report good/bad results. Thanks....Stan
ntmcj
08-31-2005 21:58:54
 Re: Rust neutralizers.. in reply to Stan(PA), 08-31-2005 13:45:51
I have used a product called Rust Converter which does the same thing as you are talking about. I used it all over an old Dodge M-37 I bought for use on the farm and on an old F-350 which spent its life in a peach orchard exposed to the corrosive chemicals used there. Both were extremely rusty and had lots of scale. I wasn't too concerned with a showroom finish, so I used a wire brush sander to get the heavy scale off and then a orbital sander to smooth it down. I applied the Rust Converter as sparingly as I could without getting too many brush marks and very lightly sanded it when it dried. The finish wasn't too bad, actually good for what I started with, but not showroom at all. Rust prevention was my main motivation though. They both have held up well for a couple of years with no rust popping back thru where they were treated. I also primed with Rustoleum rusty metal primer before I painted.
Keith-OR
08-31-2005 21:33:19
On the following website, there is a good article on restoration using electrolysis and the acid you are talking about which is "Phosphoric Acid".
On the home page click on "Restoration tips".HTH..Keith
Loren
08-31-2005 17:29:58
I remember one of the products is/was Ospho.
Mn Bob
08-31-2005 17:24:13
Some of the old timers that used to give such good advice on this net are not active here anymore. I do remeber one that turned the metal black, then you painted over it. I dont remember the name but did a google search on rust inhibitor and got some good sites. Check them out. Hope you find something good. Let us know.
Dano50
09-01-2005 11:24:40
 Re: Rust neutralizers.. in reply to Mn Bob, 08-31-2005 17:24:13
The best thing out there to prevent rust is Fluid Film. It will also stop rust on contact from spreading further. John Deere carries it.
