Tractor Talk Discussion Forum
CASE VAC
scott vaughan
08-30-2005 18:33:25
I have a lot of oil in the radiator. There is no water in the crankcase. Does anyone know what would cause this? Is the waterpump intergal with the oil pump?
MAC in TX
08-30-2005 20:05:02
 Re: CASE VAC in reply to scott vaughan, 08-30-2005 18:33:25
Scott, The oil pump is located in the crank case and is not conected with the water pump. I had a similar problem with my VAC about a year ago with oil getting into the radiator. Mine as it turned out was a cracked block between cylinders 3 & 4. There is an oil passage going between 3&4 and it was pumping oil into the water jacket. There is an oil passage going up to the head between cylinders 2&3. It could be that the head gasket is letting the oil to get into the water jacket at this point. Mac
