Tractor Talk Discussion Forum
John Deere 70 Deisel magneto/distrubutor
Farmall F-20 ma
08-28-2005 19:25:27
have a freind that is having problems with a John Deere 70 deisel magneto/distrubutor. what is happening is the magneto/distrubutor for the pony engine when you start it up the mag/distrubutor starts smoking right away is the points and condensor bad or is it the coil need a little help Thanks
Glen in TX
08-28-2005 20:22:48
 Re: John Deere 70 Deisel magneto/distrubutor in reply to Farmall F-20 man, 08-28-2005 19:25:27
That is a Wico B4027 6 VOLT battery distributor. Not a magneto. It's was designed to run on 6 VOLTS ONLY! NEVER 12 Volts, not even a 12 volt boost. It will fry the coils and never fire or fire right again. Also if the switch is left on when engine isn't running it overheats and can fry the coils. A resistor also goes in line by the switch to the distributor terminal. If you ran it on 12 volts it's beyond help and needs coils and condenser and resistor and probably points. Some others have designed a safety switch set up that kills power to the dist. after engine oil pressure drops and engine is off to prevent coil burn out. You can find that on the JD forum by searching.
buickanddeere
08-28-2005 20:29:16
 Re: John Deere 70 Deisel magneto/distrubutor in reply to Glen in TX, 08-28-2005 20:22:48
Have to wonder why the same question was re-posted less than four hours the 1st? 1-800-522-7448 for the manuals.
Glen in TX
08-28-2005 20:52:23
 Re: John Deere 70 Deisel magneto/distrubutor in reply to buickanddeere, 08-28-2005 20:29:16
I wondered the same thing when running into your answer below? lol. Oh well. I bet it's a fried critter.
