Tractor Talk Discussion Forum
Farmall A clutch
Harold Spofford
08-25-2005 15:36:26
I installed a new clutch plate, pressure plate and bearing. It still does the same thing. Whenever I push in the clutch about 3/4 of the way down, it grinds and bounces hard back on the pedal. The gear box seems OK because if it is in neutral I can start the engine and it runs great. I can also put it in any gear and push in the starter and it will move. I can push in the clutch in without the engine running and it seems to be OK. I can see the bearing push in the pressure plate arms. What can the problem be?
ben brown
08-25-2005 15:57:15
 Re: Farmall A clutch in reply to Harold Spofford, 08-25-2005 15:36:26
it sound to me like you release finger are hitting the clutch plate causing it to kick back the release bearing slides on a tube some time thies become dis lodged cusing release bearing to be miss alined. you could be pushing the release bearing in to far also
Harold Spofford
08-26-2005 10:14:39
 Re: Farmall A clutch in reply to ben brown, 08-25-2005 15:57:15
ben, Thank you for the info. I will check out your suggestions tonight. Again thanks for the quick response.
