Tractor Talk Discussion Forum
IH #15 baler help
Jerry Wallen
08-23-2005 15:33:40
I am in need of a pattern or drawing of the feeder board for a IH #15 baler--also need the same for the blocks--thanks Jerry
j cook (iowa)
08-23-2005 17:27:57
 Re: IH #15 baler help in reply to Jerry Wallen, 08-23-2005 15:33:40
I have never seen or heard of an IHC #15 Baler, although something like 50-55 years ago they DID make a 45T baler. What does this baler look like? If what you have is a #45T, i would suggest that if you are trying to rebuild one to "use", buying ANYTHING else will result in you owning a better baler, and having acquired it at a price cheaper than repairing the one you have. If you are tying to "restore" an antique, so that it can be "shown", good luck!
Leroy
08-24-2005 01:58:26
 Re: IH #15 baler help in reply to j cook (iowa), 08-23-2005 17:27:57
The #15 was long before the #45. It was avaible as a stationary or field baler with a ground drive pickup. It was also a wire tye that had no needles but when it reached the length of bale you wanted you droped in a wood block, had special features for this, then one person on one side pushes a precut length of wire with a twist loop on one end in and someone else on other side would take the end of wire and push it back thru the next block in front and first person would take the loose end of wire and put thru the pretwisted loop and twist only the strait end of wire to tye bale and when bale was pushed out you picked up the wood block and put it back up in the block inserter part of machine for reuse. This type of baler was designed in late 1800's and production was discontinued about 1950 by all brands. His baler could be anywhere from about 1910 to 1940 range, possibly slightly outside that either way. My blue ribbin shop manual is misplaced or I could get more information
Nebraska Cowman
08-24-2005 00:29:47
It's a hay press. Sorry I can't be more help.
third party image
