Tractor Talk Discussion Forum
Snow plow or snow blower?
Mike in Ind.
08-23-2005 12:58:16
Hey guys I need some suggestions. I am looking at buying somthing to move the snow on my drive this winter. I figured a snowblower would be best but I have a gravel driveway. Will a snow blower pick up the gravel as well as the snow? Thanks.
WiCraig
08-24-2005 18:54:01
 Re: Snow plow or snow blower? in reply to Mike in Ind., 08-23-2005 12:58:16
Wow, this is getting as much response as some of the political questions. Plowing is way fast, but late in the season, when the snow piles along the drive are 4 to 5 feet, you have to get the snow further from the drive. Or else you end up with a drive 6' wide. Craig
Nolan
08-24-2005 05:06:18
To answer your question, you can set the depth of a snowblower to keep it from picking up the gravel and rock in an unpaved driveway. It's what I have mine set at and I don't have any problems with the gravel driveways I clear with my snowblower.
Having had an old Ford with a rear blade and a loader, I wouldn't go back to clearing with either of them for love nor money.
Farmered
08-24-2005 04:46:11
Neighbor spent a considerable legnth of time telling how great his tractor-blower combination worked. After about twenty minutes of blowing snow into the wind the three foot load on top of his Heat-Houser canvas cab collappsed the whole thing on him. The resulting rant melted a considerable amount of the white stuff. Ed
john d
08-23-2005 23:01:57
You've already got a bunch of opinions, but I'll give you mine anyway. It depends a lot on what kind of tractor you have. I have a 40" tall loader-mounted blade that I have used on my Farmall M and SM. That's a lot more fun and effective than a rear-mount blade. A snowblower would be great, but I don't have live pto.
If you have a light tractor and live pto, get the blower. If you have an old Farmall, Deere, whatever without live pto, get a blade on the front of it.
Butcher
08-23-2005 20:35:30
third party image
This is the only way to go as far as I am concerned. Sore neck or not!
Rod F.
08-23-2005 19:49:34
Start thinking in terms of how much snow you have, what tractor you have, and how much time you have to move snow. Unless you have a large V-plow, you won't do squat in a 4 foot drift with a plow blade. It's difficult enough with a good loader. I've seen drifts so hard that a blade won't mark them, just ride up and over. You need a blower for that. I always mount the blower on my loader tractor, so I blow the worst pieces, and plow the rest with the loader. I don't look at it as an either/or question. Both have a purpose. Plowing is quicker if it's easy going, but the tractor is worked mercilessly hard plowing deep snow. And I've plowed deep snow that was too wet to blow. Then I wished I had a 950 Cat loader. I've also plowed with a Cat D4H, but it's got to be bad. Scalping a little gravel is really the last thing on my mind. Here in eastern Nova Scotia, when we get a good northeaster, the snow is heavy, wet, and deep. It can, and will challenge any piece of equipment you throw at it.
Rod
Slofr8
08-23-2005 18:47:42
I used a walkbehind blower for years and plowed for the last 3 years. I now plow my drive, my elderly parents drive, and the drive of the house we're building. Plowing is so mush faster it is the only answer for me rihgt now. I'm having a back blade plate but on my Fisher plow this year and it'll be even faster.
That said, I prefer the look of the neat job that a blower does. I'll have a big blower on a tractor someday!!
Mike Van
08-23-2005 18:02:43
You didn't say tractor mounted or walk behind blower, so i'm guessing walk behind - If you have a lot of driveway, you need lots of time, they are slow. Most people i've seen using one look like a Yeti, the blown snow has a way of covering the operator when the wind shifts. I vote plow, you have to be carefull till the ground freezes good. The piles make great play areas if you have kids.
Rod in Smiths Falls, ON,
08-23-2005 17:56:25
Ask old guys about blowing snow and you'll get loud responses about sore backs from twisting around driving backwards all day and snow down the back of your neck.
As a "kid" of only 54, however, I much prefer the snowblower to the blade. It gets rid of the snow and greatly reduces drifting. Once you know your route and have a bit of snow-pack on it, it works very well. Put new gravel on the driveway only in spring.
I particularly like the snowblower's ability to take on extra work such as running a driveway a half-mile to the sugar bush through 18" snow, with crust, so that you can drive back there, if you wish. It just chews it up and spits it out. Small, dead branches don't seem to be much of a problem, either.
Add to your equipment list a good snowmobile suit, the best snowmobile mitts you can afford, and most important, a Bell-type, full-facemask helmet. Nothing else will keep the snow out of your eyes and nose when you have to turn the discharge upwind to avoid a window on a building, for example, or your wife's car.
I bought a used, 5' model, by most standards small and narrow for a 37 hp tractor, but it works well in restricted areas and I have yet to encounter a drift I couldn't devour in one pass.
08-23-2005 17:55:02
Jim in NH
08-23-2005 16:57:01
Hi,
I'm in NH, and live at the top of a hill. Driveway is about 1/2 mile, up hill to the house(15% grade in spots), twisty, and gravel.
After early fall and late spring snows, I use a grader blade on the back of my IH584. It allows me to carefully control the depth. Best to leave a bit of snow rather than tear-up the road.
After the ground freezes, I generally plow if the storm has left me with less than a foot or so. I always push the snow to the downhill side of the road so the spring run-off will drain away from the road.
If we get 2-3 feet, I first make a couple passes with a 7 ft wide blower on the back, leaving 3-4 inches of snow, then go back and plow that off. If I try to blow right down to the ground, I invariably pick-up gravel, sometimes shear the pin, and always end-up packing down a layer of snow on the road, which is then nearly impossible to plow off.
All of my equipment was purchased used, $500 for the plow, $1200 for the blower, and has done fine. If there are direction changes or switch-backs on your road, then you will want hydraulic rams on the plow and blower chute direction.
Best of luck,
Jim
JMS/MN
08-23-2005 16:25:02
Around here it is a no-brainer. BLOW the snow fifty feet to the side for the majority of the winter- get it out of the way. Plowing makes a windrow that drifts in right away. When March comes, with its wet snow, the plow is ok, since it is hard to blow, and it will melt away soon.
thejdman01
08-23-2005 15:41:52
wow what a loaded question. no actually a blower will eat less gravel then a plow ususally esp with an inexperienced operator. blowers have "shoes" adjusted to the right height wont eat any gravel. a plow wont eat any gravel either if you set the plow at a desired height and go with it but if your driveway is wavy then that wont work. a plow in float usually eats and pushes alot more gravel then a blower. blowers take alot more ponies though but you can get rid of the snow instead of piling it up. also if the tractor isnt terribly weighted down a blower will work better. if you dont have a live or independent pto shy away from the snow blower you cant let it catch up. i know you didnt ask about that but thought i would add what knowledge i could as theres mroe to consider about your purchase then just the amoutn of gravel
DaveInMI
08-23-2005 15:27:53
I use a back blade on one tractor and a snow blower on another. I use the blade on light snows and scraping the hill down to gravel. The bottom sliding surface of my blower is a grader blade. I shorten the top link to make a layer of snow pack the first couple of snows. Later I lengthen the top link to cut down to the snow pack.
old
08-23-2005 15:09:26
My self I like a good V plow, made my own and it works just great. 8-1/2 foot wide and one pass and I'm done, also being a V you can steer well also. I have pushed 2 foot of snow with it and not had to put the chains on either.
Jay (ND)
08-23-2005 13:47:48
Yes it will but if you set your skids high the first few times blowing, you will build up hard pack and then you won't have to worry about the rocks.
Ken Macfarlane
08-23-2005 15:09:28
 Re: Snow plow or snow blower? in reply to Jay (ND), 08-23-2005 13:47:48
I'm from Canada, we have 6 or 7 ft blower and plow truck. If you have room to pile snow the plow is so much faster you wouldn't believe.
If no room the plow is a heap of useless metal!
mike brown
08-23-2005 17:09:33
 Re: Snow plow or snow blower? in reply to Ken Macfarlane, 08-23-2005 15:09:28
I'm in NY south of lake ontario. I use a front end loader. I would recomend the loader because it has far more year 'round uses than a snow blower for abpout the same money.
KRUSS
08-23-2005 18:52:03
 Re: Snow plow or snow blower? in reply to mike brown, 08-23-2005 17:09:33
I am from Manitoba. If you have lots of power, lots of traction and a place to put the snow a blade is the way to go. Used to be a lot of blowers around here, but not many anymore. I have a 12 foot Degelman blade on an 8100 JD.FWA a lot more money than most people want to spend, but the tractor I need anyway, I do some custom plowing and I rent out the tractor to pile silage. And it is awesome in snow!!
