Tractor Talk Discussion Forum
Magneto Question
Kelvin
08-21-2005 12:31:06
I am trying to fix a Minneapolis-Moline JTU to run, It has a Waukesha engine.
The magnet on the Original Fairbanks RV4B magneto is dead. I have tried to start it on a Fairbanks FMJ but all I get is a pop every now and then. My manual only shows only how to set the static timing (At top dead center), but not the run timing.
Can I install the RV4B impulse on the FMJ to be sure I am getting the correct spark advance?
If you don't know, can you suggest someone I could check with?
Thanks!
Kelvin
Larry from MD
08-21-2005 15:26:54
 Re: Magneto Question in reply to Kelvin, 08-21-2005 12:31:06
Your tractor should run fine on the fmj mag.Did you time the rotor inside the mag?Does the impulse snap on the fmj at tdc or just after?Try the moline board.
