Tractor Talk Discussion Forum
differential locked on massey 135
Eddie C
08-20-2005 18:44:43
I have a massey 135 the diff. pedal will move easily up and down but the differential stays locked in, does anybody know how to unlock it? what do I need to do.
Leroy
08-21-2005 18:35:51
 Re: differential locked on massey 135 in reply to Eddie C, 08-20-2005 18:44:43
What I have had experiance with are John Deere and Ford. The lock will not engage unless you are moving and to release hit a brake pedal like for turning
Farrviewsouth
08-21-2005 17:45:36
On my 135, you need to turn the wheel (right or left fully, I forget which) while you are moving.
That makes the lock release.
Hugh MacKay
08-21-2005 03:19:33
Eddie: I haven't had any experience with M-F, but my thoughts would be go to M-F or Ferguson page with this question. Most diff locks the pedal is spring loaded. When you push down it pushes a plunger in. Problem happens when you let pedal up the plunger is sticking and does not pop out. Usually this is just a cleaning proceedure to cure. We do know your diff lock is still working, thus I would expect you have a simple fix.
