Tractor Talk Discussion Forum
270 jd diesel engine
sphargy42
08-19-2005 06:47:22
Was wondering if you folks know what old combine use the 270 diesel engine . currently looking for a take out engine for a 500A backhoe. wonder what they run for a used engine ? any help is greatly appreciated .
Mike M
08-19-2005 19:18:46
 Re: 270 jd diesel engine in reply to sphargy42, 08-19-2005 06:47:22
Unless your block is cracked you should be able to rebuild yours.
105Diesel
08-19-2005 12:46:38
There were not any John Deere Combines that used the Waterloo-built 270 engine. It's only application was in the "3010" and "3020" based agricultural and industrial tractors. It was available for a time as power unit for irrigation, etc.
sphargy42
08-19-2005 13:22:43
 Re: 270 jd diesel engine in reply to 105Diesel, 08-19-2005 12:46:38
Thanks fellers . It is very hard to find any info on the 500a backhoe too. Maybe we are looking at a rebuild the way you all talk. If anyone knows of any 270 engines please let me know. Thanks again .
J. Schwiebert
08-19-2005 14:02:52
 Re: 270 jd diesel engine in reply to sphargy42, 08-19-2005 13:22:43
There are also some major differences in the early 270 and late 270 engines. do you have serial number tag on your engine? does your block have "weep holes on the manifold side or better yet do you have a block casting number?
sphargy42
08-19-2005 17:56:52
 Re: 270 jd diesel engine in reply to J. Schwiebert, 08-19-2005 14:02:52
The only numbers I have so far are Type-E0097 ,
serial- 0003100 but I am not sure of this serial, we got them on the right rear axle housing . I will get the engine serial as soon as I can . Do you know exactly where it is on the block ? It has power shift trans , looks like a vane motor on the swing on the hoe. some say this is bad. sure is exciting !! Thanks again for any and all help.
Stum
08-19-2005 08:11:42
I believe the 4400 or 4420 combines used that engine,same engine in 3020 tractors. They are getting scarce and pricey. I hunted for 3 months to find a good block for my 3020.
RickB
08-19-2005 16:18:31
 Re: 270 jd diesel engine in reply to Stum, 08-19-2005 08:11:42
Not. They used the 6 cylinder 329/359 Dubuque engines.
