Tractor Talk Discussion Forum
Satoh 370D 4WD axle leak
Shay
08-14-2005 22:38:50
I bought a Beaver 370D 4WD last year. It has an oil leak at the front axle, mostly on the left side. Does the oil from the front differential case also go to the final drive case? Can I fill only the differential or do I need to fill that little hole way inside the wheel rim (very hard to fill)? The leak is where the four bolts are where the differential case meets the final drive case. Is there a seal there that I should replace? I hope I'm using the right terms, I'm no mechanic.
VaTom
08-15-2005 03:35:30
 Re: Satoh 370D 4WD axle leak in reply to Shay, 08-14-2005 22:38:50
If it's like my slightly newer and larger Mitsubishi, the whole front drive's connected, oil-wise. The small hole would be to tell you when it's full, oil comes out.
What you really need is a manual. Help, manuals, and parts can be found at:
