Tractor Talk Discussion Forum
Ford 445D specs ?
TomWNC
08-11-2005 23:04:19
Trying to find some info on a Ford 445D. Horse power and weight mainly, but any info I can find would be great. Have searched with no luck and hoped someone here would be able to help me out or point me in the right direction to find it.
Tom
Br549
08-15-2005 11:56:57
 Re: Ford 445D specs ? in reply to TomWNC, 08-11-2005 23:04:19
If your 445d is a turbo, It is 67 Hp at the flywheel. 4000 lb. full lift cap. on loader. can't find the spec right now, Butprobably
9000 lbs with water in tires
TomWNC
08-15-2005 20:45:39
 Re: Ford 445D specs ? in reply to Br549, 08-15-2005 11:56:57
I don't believe it is the turbo version. It does have water and wheel weights on the rear wheels, not sure about the front. The tractor belonged to a friend�s dad and she has inherited it. Trying to find out some basic info about it for her.
Rod F.
08-13-2005 07:00:28
I'm not really sure of the spec's on that model. I know that the 445 was an industrial variant of the 4000-4600 series tractor. That should make it 52 hp, at the PTO, or roughly 60 at the flywheel.
I would guess that with a loader, it will tip the scale around 10000 #'s. That's just a rough guess. They've got fairly heavy loader frames, heavy front axles, and quite a bit of plating around the cowl. Underneath, it's basically a stripped down 4600. You might check NH's website. There may still be specs on there for the 445D. HTH.
Rod
Leroy
08-12-2005 05:22:58
What are you looking at? a tractor? Know of NO Fords with a model no like that. Moline made a tractor with model no of 445D
TomWNC
08-14-2005 13:07:36
 Re: Ford 445D specs ? in reply to Leroy, 08-12-2005 05:22:58
It is a Ford Industrial model has 4wd and a front end loader.
