Tractor Talk Discussion Forum
I need help with my tractor
matthewsims
08-09-2005 18:44:23
I have a McCormick International W-6 and would like to get it going. if anyone can give me advice I would be very greatful.
matthewsims
08-10-2005 20:57:43
 Re: I need help with my tractor in reply to matthewsims, 08-09-2005 18:44:23
I should have said that it has been sitting in a paddock few several years and there isn't even a battery on it. There isn't any wiring but I have spark when I crank it with the handle.
Do I need a battery.
I would like to fine out how old it is as well.
skipper
08-10-2005 05:26:06
One other thing it needs -- FRESH GAS. If the gas is really old and lost it's vigor, and you can tell by the smell sometimes, you can have all the compression, spark, right timing, and old gas in China, but it will just not start. If it has sat a long time make this a priority.
Skipper
Mike (WA)
08-10-2005 18:33:56
 Re: I need help with my tractor in reply to skipper, 08-10-2005 05:26:06
And in our present day and age, "old" gas is anything that has sat over a hot summer- best first step is to drain the gas and replace.
Joe in Minnie
08-10-2005 04:45:13
Sounds like from your information, all you have to do is tow it around the yard for about 30 minuties and keep popping the cluch, when that don't work, then call a good mechanic, he's get it going fur ya....LOL ..good luck,,,,,
DaveInMI
08-10-2005 04:05:16
It needs compression, fuel, good spark, and with proper timing. Step one is to find which one of these is missing.
I Like Case
08-10-2005 03:32:47
I hadn`t been planning a trip down under but if you`ll pay my way I`ll help you get yer tractor runnin.
Seriously we need a little more information here if we are going to be of service to you. What is or isn't it doing?
wayne2
08-09-2005 20:52:48
Start with hot battery,check spark at points, clean fuel system(tank to carb)turn key pray if no fire repeat steps 1 thru 2. Goodluck Wayne
