Tractor Talk Discussion Forum
Ford 4100 Fluid
ClayMask
08-09-2005 14:29:47
I have a 4100 Ford and was wondering what the capacities and type of fluid to put in the rear end and transmission? Are the fluids seperate or do they share the same well?
Thanks
IanC
08-09-2005 19:11:26
 Re: Ford 4100 Fluid in reply to ClayMask, 08-09-2005 14:29:47
Fill in two spots (by shifter & rear axle center section), drain in three. '65 and up 4000 series have wet brakes, and if you use the wrong fluid the glue on the friction disc can let go. Use Ford/CNH 134 fluid, the savings from the ElCheapo oils are not worth the damage they can cause.
