Tractor Talk Discussion Forum
problem with 3 point hitch and pto
Ric
08-08-2005 11:39:35
Would like to know if anyone knows why my pto has to be on to make the hitch work this has a lever for the pto to be in or out if you move lever just a little it will go up without the pto being on. What is the problem?
cd in tx
08-08-2005 17:28:01
 Re: problem with 3 point hitch and pto in reply to Ric, 08-08-2005 11:39:35
u have an 8n dont u
MSM
08-08-2005 14:35:33
If it is a Deere utility,it could have a cut oring on the pto valve,split gasket,a cracked hydraulic tube,or a blown pto brake seal. This is fairly common,as the tractors get older.This is just a quess,since you didn't specify make/model.
Ric
08-08-2005 12:23:22
do you have a number that I can call you?
old
08-08-2005 14:23:24
 Re: problem with 3 point hitch and pto in reply to Ric, 08-08-2005 12:23:22
Drop me an e-mail and I'll be happy to give you my phone number
old
08-08-2005 12:14:40
Can not answer your question with out knowing what tractor you have. I'm guessing its one of the ford Ns and if it is you need to pto on for the 3 point to work the hyd pump is run off the pto
